Why sand fiberglass?
Postby tjdeerslayer37 » Wed Nov 14, 2007 11:45 am
why do you have to sand the clear coat off the fiberglass? i realize it makes sure you have the same finish on the whole bow, but the factor finsih is perfect. so how come?
oh and i wasnt sure if i should put this in the bowyers gallery or whatever so i put it here and figured it could be moved if need be.
thanks
Re: Why sand fiberglass?
Postby Gino Bruno » Wed Nov 14, 2007 8:42 pm
TJ, the shiny side has a release agent on it..... nothing will stick to it very well including epoxy.
Postby Cutty » Thu Nov 15, 2007 12:04 pm
Hey, TJ...I haven't had a chance to welcome you here yet. I wish I had started learning about this stuff when I was your age. Thanks for asking that. I'll be learning along with you. :D
Cutty
Postby tjdeerslayer37 » Thu Nov 15, 2007 5:12 pm
what i meant was more like, why not just leave the factory coating on as the final finish, and just finish the sides and the riser?
just a thought and im sure theres a good reason no one does that
oh and thanks cutty :)
