Amateur Bowyer's Gallery
Re: Amateur Bowyer's Gallery
Postby Sixby » Wed Jun 11, 2008 12:09 am
This is a strike Eagle recurve super fancy fiddle back myrtlewood and english walnut Carbon limb 55 lb 58 in bow.
56 in 60 lb EagleWing onepiece that pulls 29 with no stack, This riser has a semi Gloss finish on it per request. It is Koa and Myrtle with bloodwood I beam. This was one of my favorite bows with a gorgeous fiddleback myrtle veneers and fleur de lis inlays of contrasting myrtle. If I was ever envious of a customers bow this is it. Someday I will just have to do a redo on this one.If you look you can see the fiddleback in the veneers in the pic. It is that heavy of fiddleback. This whole bow just glowed.If I had been a bit more careful with my shaping in the riser window and got the maple to match up I could almost have called it perfect. How I missed that I don't know. Look at the irredescence in that koa though. I don't want to even tell you what I paid for that piece of wood. It was sinful but I couldn't help myself.
Sixby
Postby BLACK WOLF » Wed Jun 11, 2008 9:57 am
Blackfoot reproduction. 46" sinew backed chokecherry, vermillion red paint, beaded brain tanned buckskin, horse hair, red flannel cloth and green thread. 45lbs. @ 23"
Blackfoot Bow.jpg (22.67 KiB) Viewed 9842 times
Blackfoot Bow 2.jpg (27.89 KiB) Viewed 9828 times
Modoc Reproduction. 36" sinew backed yew, acrylic paint, brain tanned buckskin. 20lbs. @ 18" given to my old bosses little boy
Holmgaard Hybrid. 64" osage, Diamond Back Rattlesnake skin, acrylic paint, coyote fur. 52lbs. @ 28"
Osage Holmegaard Tips.jpg (105.53 KiB) Viewed 9828 times
Holmegaard 2.jpg (22.43 KiB) Viewed 9812 times
Plains Indian Hybrid. 60" sinew backed osage, Diamond Back Rattlesnake skin, acrylic paint, brain tanned buckskin, coyote fur. 63lbs. @ 29"
Plains Hybrid Side Profile 2.jpg (29.64 KiB) Viewed 9803 times
Plains Indian Hybrid.jpg (35.32 KiB) Viewed 9796 times
Mohawk Reproduction. 64" hickory, red and green yarn, acrylic paint, red and green thread. 35lbs. @ 28"
Mohawk Bow 3.jpg (24.15 KiB) Viewed 9795 times
Mohawk Bow.jpg (102.43 KiB) Viewed 9784 times
Plains Indian Horn Bow. 32" sinew backed Bighorn sheep horn. 60lbs. @ 16"
Sheep Horn Bow.jpg (63.29 KiB) Viewed 9785 times
BLACK WOLF
Postby Mike Baker » Wed Jun 11, 2008 10:13 pm
Here are a few of my favorites I've made. I can't recall specs of them but I liked the wood combos.
This is the one I currently shoot. 62" 49#@28" zebrawood and wenge with a splash of cocobolo. Flat grain zebra limbs with wenge splice. Deer track inlay.
Osage, cocobolo and bloodwood riser. Moose antler overlay. Bleeding heart inlay.
cocobolo/bacote with a yellowheart flare.
My computer is about to crash so I better stop.
Mike Baker
Postby VRB » Thu Jun 12, 2008 12:23 pm
Nice looking bows guys.I think this gallery is a great idea,I never get tired of looking at the different wood combinations and design ideas. Since I was forced into semi-retirement with a plant closing,I have been making more bows.Here's a few that I have done.
Bill
60" 54#@28"
Tiger maple 005.jpg (169.46 KiB) Viewed 9810 times
58" 44#@28"
birdseye&cocobolo 12.jpg (238.57 KiB) Viewed 9804 times
58" 54#@28"
Birdseye and Bacote 001.jpg (211.98 KiB) Viewed 9632 times
VRB
Postby 4nolz » Sun Jun 15, 2008 9:09 am
well I have tried to find pics-fact is I started making bows before I was ever online.I learned by reading all the TBB's and HOB-the pages are highlighted and underlined like a college textbook! I have since learned alot (and its easier) online by places like this.Alot of my early pics are on floppy disc which I cannot use now.A letter to Dean Torges and his gracious help was how it all started.
Of course I started out with selfbows and still make them.Nowadays they are mostly short bend thru the handle osage bows.
Postby 4nolz » Sun Jun 15, 2008 9:13 am
I started making 1 piece longbows-Hill and RD most of which were 66".I dont have those pictures.
I made some 3 piece TD longbows experimenting with RD and Shallow limbs and 3 different limb pad angles.here's a couple.
Postby 4nolz » Sun Jun 15, 2008 9:17 am
the most fun I have had was designing and learning to make short recurves.These are ~49".I made some sprayed with black truck bedliner for use in turkey blinds-short and manueverable and black.
Postby 4nolz » Sun Jun 15, 2008 9:25 am
I was an avid Bear bow collector before I started making bows.I was surprised to find I didnt have many photos of my "homage" which is a 59/60 Kodiak copy.I wrote some articles for TBJ on making the form then buidling the bow.
Unfinished against the original (I used dymondwood)
Postby 4nolz » Sun Jun 15, 2008 9:30 am
Every summer I try to "assign" myself a new task to learn.My main problem is I hardly ever shoot the same bow for more than a couple weeks,I'll kill something then put it away or give it away.Last summer's project was to start shooting 3 under,design a short takedown,and do curved riser accents.Ended up with a 56" takedown and shot it real well (4 deer and some hogs) but it is so much louder that I am not going to hunt with it anymore.
I also made molds and cast the antler limb bolts they are not real.
Postby 4nolz » Sun Jun 15, 2008 9:36 am
I also experimented with changes in TD limb length and amount of "recurve".This is a 60" bow I made for a bear hunt (I ended up not going),meant to be indestructable-sprayed with bedliner and knurled limb bolts.This was about the time I discovered POA and asked questions about changing the limb profile.Ended up with a quick bow BUT you need to use a stringer for these they are very prone to twist.
this shows some profiles of various takedowns including a PSE compound I made for bowfishing the so-called PSERF bow (PSE retrofit).The one on the bottom is an early OL Adcock 3 piece the others are mine.
PSE's
