by Robertfishes » Wed Feb 18, 2015 11:11 am
I built my form and wedge jigs, got a couple sets of limb detent assemblies from Lancaster...now i need to glue up my first set of limbs, here's my problem.. Stack height..The only ILF limbs I have access to are SF carbon wood shorts and SF carbon foam longs. I know the double carbon in these limbs makes for a thinner stack, but what about the foam? Is it stiffer than amberboo or maple? I didn't copy the SF limbs i added more hook..for the first build I'll be building longs from fiberglass and wood limbs. I plan on using 040 clear glass, pretty veneers, red elm tapers with 003/in total taper. Shooting for a lower draw weight for the first set, 35@28"..that way I might not end up with 80# limbs.. Anybody have a set of glass and wood limbs they can grab a thickness from, up by tip overlays is OK, I can add 003/in from there. I know it will still be a guess for the first couple of limb sets...Thanks, Robert
Robertfishes on Tue Mar 03, 2015 9:38 am, edited 2 times in total.
