Bow from a branch
Bow from a branch
Postby rgibula » Wed Dec 17, 2014 4:26 pm
I have had feelers out for a piece of local serviceberry for a long time and I finally got one. This is supposed to be a very hard wood and was used by native americans for bows.
Whatever wood I use, however, I am worried how to cut it. This is a branch, about 5 feet long and just over 2 inches thick. It comes in a natural curve. I think that the shape would allow for a natural recurve shape.
The problem is that it's a branch. It does not have flat grain areas. If I cut out the center, the grain will be 90 deg from what you normally use for a selfbow. I could cut an edge off and leave a D-shape where the grain will be as flat as it can be, making the most curved part be the back of the bow.
Does anyone have experience making a bow from this size of wood and will reinforcement be necessary?
rgibula
Re: Bow from a branch
Postby marc » Thu Dec 18, 2014 9:15 am
I moved it to the bowyers gallery where you will get more visibility from the guys that build bows.
marc
Postby rgibula » Thu Dec 18, 2014 9:24 am
Thanks
rgibula
Postby rgibula » Fri Dec 19, 2014 5:51 pm
Maybe a few specifics would help:
Should I split the branch now, or after its dry?
Should I pull it with the existing curve, like some websites say, or should I string it from the convex side and make it like a recurve?
Should I cut it in half first to reduce the chances of splitting incorrectly, then shave off the excess, or just try to split it the whole way?
Should I leave it as a D-shape or trim the back flat?
rgibula
Postby superkodiak38 » Sun Dec 21, 2014 11:58 am
I don't know much about Serviceberry I would think you would let it dry, peel the bark and leave the back intact then start reducing it while exercising it. If you split it I don't think your going to get much weight out of it. Also unbacked it's going to have string follow so I would say holding it in your hands I would want the curved ends facing away from me giving it some natural deflex. I have a copy of the Traditional Bowyers Bible somewhere if I come across it I will let you know what it says on Serviceberry.
Postby rgibula » Sun Dec 21, 2014 12:28 pm
Thanks for your help. Serviceberry is so hard, I cannot bend a 1 inch branch by hand, even green. Given that is it 2 inches thick, I feel bad if I throw half of it away, but I would rather do that than wreck it.
rgibula
Postby superkodiak38 » Mon Dec 22, 2014 7:57 am
Here is what I could find: Peel it, saw it, don't split it or you will get twist. It is a white wood, so leaving the back intact is probably a good Idea and sinew backing is too if it comes in light. Some recommend clamping it into a caul or to a board to dry to keep it from twisting. Wish I could tell you more, post some pics and tell the tale when you do the build ;)
Postby rgibula » Mon Dec 22, 2014 8:33 am
Thank you, that is very helpful.
rgibula
