Stabilizing Wood.
Re: Stabilizing Wood.
Postby Crooked Stic » Sat Mar 15, 2014 4:44 pm
I got some color to go in the Cactus Juice. I got in no hurry on this one and I think it paid off.I vacuumed three times with soak time on the first two double the vacuum time. Then after the third vacuum of a couple of hours I let it soak four days then cured it.The color got all thru the wood and gained a lot of weight. I squared the block up and sanded to 180 grit and put some rattle can poly on it to bring out the grain. Turned a fairly plain piece into a nice looking riser block.
Postby Chemsolder » Sat Mar 15, 2014 8:06 pm
Awesome! Been thinking of trying to dye some woods in order to avoid stains seeing what it took....wow I am impressed The results are phenominal!
Chemsolder
Postby Iktomi » Mon Mar 17, 2014 7:58 pm
How do ya think that cactus juice will behave with the epoxy when it comes time to glue 'er up? Hopefully the 'pox will stick to it.
"I’d have my cock out if I scored four goals. I’d have my cock out, stroking it."
Joe Thornton, Captain of the San Jose Sharks :lol:
Iktomi
Postby Crooked Stic » Tue Mar 18, 2014 4:04 am
That is one of the first questions I asked before getting into this project. Curtis of Turntex said he has used epoxy and titebond all with good results. I also asked how it would react to heating in the hot box after curing. He said it will be fine up to 400 degrees.
Postby mike robin » Tue Mar 18, 2014 6:29 am
mike
what dye and color did you use ?--and it was mixed right in the cactus juice?
it looks great!
chicks dig me
mike robin
Postby Iktomi » Tue Mar 18, 2014 6:37 am
That's good news. Epoxy is funny about bonding with certain plastics.
Crooked Stic wrote:That is one of the first questions I asked before getting into this project. Curtis of Turntex said he has used epoxy and titebond all with good results. I also asked how it would react to heating in the hot box after curing. He said it will be fine up to 400 degrees.
Iktomi
Postby Crooked Stic » Tue Mar 18, 2014 6:13 pm
It is a aluminite die that he sells on his site. At the bottom of this page--
http://www.turntex.com/~cactusb1/index. ... Itemid=121
Postby Crooked Stic » Mon May 19, 2014 4:03 am
I got a bow built with some of the maple. This stuff sands a cuts way different than normal wood. Kinda wants to polish out. Adds a lot of weight . Considering supplies and electric you will have about $40 tied up in a TD sized riser block.
