question on form
question on form
Postby ojibwe » Sat Feb 01, 2014 4:29 pm
I have a question about when flipping parallel wedges on my form I noticed the wedge tilts up and there is an appreciable amount of space between wedge and form.can I shim the area so when I load up my hose it has more to work against?
Any help is appreciated
Thanks
Vince
ojibwe
Re: question on form
Postby Crooked Stic » Sun Feb 02, 2014 3:38 am
To get the best results you will want the flat of the wedge to be against the form. I guess another way to do it would be a full tapered wedge then grind a small flat for the bolt area.
