Thru- Riser Insert for ILF riser Build
Postby nevadabugle » Wed Dec 04, 2013 10:19 am
Hi all,
I am in the process of building an ILF riser. I am looking for a source for either extra long 1/2 X 13 threaded inserts, or better yet the through riser type inserts that have the button head on the belly of the riser. I have a Wes Wallace recurve that uses this through riser type and it always seems more secure to me. Any help would be appreciated.
nevadabugle
Re: Thru- Riser Insert for ILF riser Build
Postby Crooked Stic » Thu Dec 05, 2013 3:45 am
I have seen Fox bows that use thru the riser inserts. Call Ron up he might be able to help you.
Postby nevadabugle » Thu Dec 05, 2013 9:53 am
I just sent Ron an Email. I'll let everyone know what he says.
nevadabugle
Postby nevadabugle » Thu Dec 19, 2013 7:48 am
I never got a response from Ron. Oh well. I did find a source for 1 inch long brass insects. Look up custom pool cue builder supplies. They use a 1" brass insert that should work for bow building applications as long as brass does not scare you away.
nevadabugle
Postby Kirkll » Fri Dec 20, 2013 7:43 pm
here you go.... these guys have got em
https://www.lancasterarchery.com/
Postby elkslayer » Sun Oct 26, 2014 12:37 pm
If your looking for the brass hardware from Fox archery I can help ya out as I make all his and Wes Wallace, and Blacktail bows hardware. I am working on some ILF hardware right now.
I HATE WARM BEER......
elkslayer
