Bloodwood and curly maple bow, finished pics p4
Re: Bloodwood and curly maple bow for friend
Postby arrowlauncherdj » Fri Sep 20, 2013 11:44 pm
Here it is cleaned up. Pad angles ground, ready to cut the front curve and finish overlays and backing
Postby arrowlauncherdj » Sat Sep 21, 2013 9:14 pm
First limb outa the form:
I did something different here, I have a maple taper and 2 aboo parallels, one being an amber for a racing stripe effect. Good glue line = happy:)
Postby arrowlauncherdj » Sat Sep 21, 2013 9:16 pm
The maple taper is on the compression side of the limb. That other small whitish lam there is my PL.
Postby chackworth3 » Sat Sep 21, 2013 9:36 pm
This is looking good!
Chris
Dry Creek Bow Company
http://www.drycreekbowcompany.com/
chackworth3
Postby arrowlauncherdj » Sat Oct 26, 2013 4:04 pm
Re: Bloodwood and curly maple bow for friend, updated pics
Postby Trux » Sat Oct 26, 2013 4:28 pm
I sure like the arch in this one...good looking glue joints too! The riser is going to pop once you add some finish.
Trux
Postby chackworth3 » Sat Oct 26, 2013 7:17 pm
Trux wrote:I sure like the arch in this one...good looking glue joints too! The riser is going to pop once you add some finish.
Yep
Chris
chackworth3
Postby Crooked Stic » Sun Oct 27, 2013 3:12 am
This is looking really good :)
Postby MoeM » Sun Oct 27, 2013 4:23 am
The riser accent looks awesome for this design, really a cool bow.
Looking forward to finished pics!
MoeM
Re: Bloodwood and curly maple bow for friend, chrono numbers
Postby arrowlauncherdj » Mon Oct 28, 2013 11:20 am
So I ran it thru the chrono last night. A little back story on the evolution of this design, I used .002 taper, same length 62" AMO... Where this one differs from past bows of the design is a flatter pad angle (10 was old, 8 is new) pushed the PL out 1", mixed cores (aboo parallel x2 and maple .002 taper). The changes were made bc this guy has a 26" draw and wanted some more speed if possible. The force draw curve is a bit different on this bow also, my old one with the 10* pad gained 2.5lb per inch out to 29", then up to 3 lb at 30". This new one is stacking sooner, 3 lb per 1" at 28" and 3.5lb at 29". Did not draw past 29" on this one.
My current bow , all maple cores 10* pad angle= 174fps 10gpp @28" draw, 178 9gpp@28"
This bow,maple on compression side, aboo on tension side, 8* pad= 185 9gpp@28"
At my buddies draw 26", 170 fps with 10gpp
I put a tape on the arrow and shot drawing til the tape touched the riser at each draw length, 10 shots each with finger release on a 14 strand d97 string rigged to hunt with wool poofs. Not as good as a hooter shooter but it got just a couple fps diff on the average each time, so I feel good about the accuracy of the results. I am happy with the progress for sure. Any thoughts on ways to improve?
Dave
