Homemade micarta for a variety of applications
Postby DIY_guy » Thu Jul 30, 2015 7:29 am
This is how I make a homemade layered resin knife handle. This is commonly done with carbon fiber and fiberglass but I've also seen it done with denim so I thought I would show how I do it. I've seen others do this with some pretty interesting results. I want a black handle and red handle so I’m making it out of an old pair of black dress pant that had a busted zipper and an old red T-shirt. I cut squares that were 4 ½ by 4 ½ so that I can get a matched set of handle scales.
This was messy work and I wore rubber gloves that quickly were covered in resin so not many pics were taken during the actual assembly of layers. I got the resin and hardener from Walmart.
I used a plastic bin to coat each square and a squeegee to spread and saturate the cloth.
I would be clamping the stack between two wood slabs. I cut apart a large Ziploc bag and taped it to the blocks to keep them from sticking to the fabric squares.
16 layers thick. Notice how the Ziploc bag material is no longer smooth and tightly stretch over the block. This stuff gets really hot. I could not hold the mixing container due to the heat.
Then I clamped them together as tightly as I could. I also made a set of thinner pieces out of a red T-shirt. I will use them for spacers. They are only 2 layers thick.
I let them set for 24 hours even though the container said it would be cured in 2 ½ .
After prying the blocks apart.
After sawing off the excess.
All that pressure did a good job of making a very solid and heavy chunk of resin impregnated cloth.
Here are the scales and spacers I cut for the knife.
I took a piece of scrap and rounded and polished it to see what the surface would look like without applying any kind of finish. I polished it on a flannel buffing wheel with Tripoli compound. It even looks a little like carbon fiber.
Since this is just an experiment , I am using one of the Chicago Cutlery factory 2nds I have on hand. I’m not sure what about them makes them 2nds but they sell them at a good price. This is just a basic kitchen knife and perfect for this sort of practice.
I used brass pins and my regular slow cure epoxy to attach the handle parts. I used a belt sander and palm sander to shape. I went from 50 grit to 400 grit sandpaper and then 000 steel wool and finally the flannel buffing wheel. Here is the finished handle made from a pair of pants and an old T-shirt.
Interesting patterns can be made by using different colored cloth layers. I plan to make another using blue jeans and some other colored fabric that my wife wont miss.
Here I use denim as well as colored construction paper.
I used another Chicago Cutlery blade.
10 layers of green construction paper. This stuff has some potential and comes in a wide variety of colors (and is cheap)
Now a Burlap sack and an old green T-shirt.
The uses for this homemade "micarta" are endless as are the material choices.
Re: Homemade micarta for a variety of applications
Postby whump » Thu Jul 30, 2015 12:51 pm
That handle turned out very nice. I made a flip stock handle years ago using the same idea with red and green nylon cloth left over from a backing project . Very nice job on your part
Postby bearauto11 » Fri Jul 31, 2015 11:21 pm
That burlap sack one has a really cool pattern.
Postby Stykshooter » Sat Aug 01, 2015 5:22 am
I like that burlap as well. Interesting thread
