Making dyed natural turkey feather arrows
Postby DIY_guy » Fri Jul 10, 2015 12:10 pm
I enjoy making my own arrows. Ive been making them for about 35 years. While I enjoy compounds and recurves,, I also make my own longbows and my own broadheads to hunt with. Likewise I make my own cedar arrows. I took a few pictures of the last batch I am working on. This not the ONLY way to make arrows. Its just one way. There is more than one way to skin a cat and while I love cats, I can’t eat a whole one by myself but I digress.
We save the wings from the birds we kill so we can make them fly again.
I like to use the primary feathers but I also use the secondary feathers if they seem fitting for the purpose.
I trim away both ends that are less than useful.
Turkeys are dirty, smelly, oily birds so the feathers need a bath in warm soapy water
Even though this turkey died once, Its gonna get dyed again. This time red but sometimes green or yellow, etc. I use RIT dye, really hot water and a little vinegar.
After a rinse and air drying.
Lots of folks use a razor knife to split their feathers and I have done it that way for years but I find a 14 tooth very thin bandsaw blade offers more control and is a bit easier/safer.
I fabricated a holder that allows me to grind/sand the base and sides of the feathers. Nothing fancy but it works.
Then a trip on the drill press against a sanding drum with a wood spacer slightly larger in Diameter than the drum to allow for consistent spacing.
I don’t chop my feather although that is a perfectly fine method to employ. I tend to burn my feathers either in advance of fletching using a simple clamp I made from office supplies and a red hot wire.
Or I burn them after fletching (also using a hot wire)
I like to dip and crest my cedars in colors that match the feathers.
I have a few fletching jigs that date back pretty far but for a bit more helical I use this newer Bohning jig.
Here is another batch.
Couple that with a homemade broadhead and it makes for one very satisfying way to pass the time and a way to increase the level of satisfaction and accomplishment when you take game with a homemade bow and homemade arrows.
Re: Making dyed natural turkey feather arrows
Postby whump » Fri Jul 17, 2015 6:10 pm
well bro, those turned out really nice
Postby Jim Casto Jr » Fri Jul 17, 2015 6:19 pm
Beautiful, and most informative. I used Rit die years ago, but just use them natural anymore. I've got a Young Feather Burner. I did make a grinding jig. But somehow, everything you do is prettier than what I do. :)
Postby BEN MAHER » Sat Jul 18, 2015 2:22 am
awesome work ...
those arrows look beautiful
BEN MAHER
Postby tjdeerslayer37 » Fri Aug 28, 2015 6:49 am
Any info on the feather burner? Im growing to dislike my choppers, not consistent enough and theyre getting dull and just annoying lol.
