Bowyers: Metal parts
This is a forum for our active members to show and shamelessly shill their goods as well as answer questions. This is reserved for members who actively participate in this board.
Postby Mann » Tue Aug 31, 2010 2:25 pm
I started making the Donkey ILF inserts a couple of months ago. Several guys ordered them so now I am offering some additional items.
I make a few take down recurves myself, so that is where my interest is.
If you would like to order please PM me.
Bezels & washers...............................................................................................................$ 8.00/pair
Double threaded 82 Deg inserts.............................................................................................$.8.00/pair
Take down set includes 1 pair each of Bezels, washers, inserts, screws, and alignment pins.................$17.00/Set
Countersink tool for 82Deg inserts (1/2" Shank)....................................................................... .$16.00/each
Donkey ILF inserts ........................................................................................................... .$33.00/pair
Shipping will run $3.00 to $6.00 depending on order
Thanks
Mann
Re: Bowyers: Metal parts
Postby mike robin » Mon Sep 20, 2010 6:50 pm
those look real nice--tell us about the blue thingies[nice riser by the way!]
chicks dig me
mike robin
Postby Mann » Tue Sep 21, 2010 7:57 am
Hi Mike
On my take downs I use a 5/16 Delrin key (blue thingy) instead of an alignment pin.
My theory is it gives me a lot more precise alignment and also makes it a cinch to profile the limbs into the riser.
I use the delrin because it is slick kind of like teflon and I had it on hand.
Mann
Postby arrowlauncherdj » Tue Sep 21, 2010 10:05 am
do you just use a router to cut the groove? Seems like a nice set up.
Dave
Postby Mann » Tue Sep 21, 2010 10:53 am
No, actually I don't even have a router, :) but I do have a Tool & Die shop so what I do is use a mill. ;)
When I do the limbs I lay out a center line and use a wiggler (a machinist tool) to pick up the line over about a 20" length then put the key in the limb.
When doing the riser I indicate it in with an indicator and then key it in the same set up I will put the brass inserts in.
Some people may say its cheating :o But I figure if I got it why not use it :twisted:
next time I do one I will take pictures.
If you had a very accurate setup you probably could do it with a router. I just never really thought about it.
Thanks
Mann
Postby arrowlauncherdj » Mon Oct 04, 2010 11:14 am
Hey Mann,
Do your threaded inserts have the same thread pattern as the Binghams ones do?
Dave
Postby Mann » Tue Oct 05, 2010 4:48 am
Yes they do
1/2-13 OD x 5/16-18 ID x 7/8 long
Thanks
Mann
Postby Mann » Tue Dec 21, 2010 6:29 am
I am sending out the last 4 pair of the Donkey inserts that I have today.
It seems as though the orders have really slowed down and I was wondering if it was going to be worth running any more.
Any body have any plans to do any more ILF in the near future? To be honest I don't care one way or the other, but if we are done with it I will just let it go away.
I like the ILF but I am doing it in an all aluminum riser myself, so I don't personally use the inserts anyway.
Thanks
JIm
Mann
Postby marc » Tue Dec 21, 2010 11:22 am
Are you going to be making and selling your risers?
marc
Postby BK in TEXAS » Tue Dec 21, 2010 11:29 am
I still have a couple pairs, but will definitely need more at some point.
Return to Member products forum
