Shooting off the shelf?
Re: Shooting off the shelf?
Postby topcamp » Mon Aug 16, 2010 8:37 am
a rest as close to shooting off the shelf as you can get............tefflon..........held on a leather pad with duro quick gel super glue...........stays put and works for me...............
bb tefflon rest# 1042.jpg (143.9 KiB) Viewed 2962 times
bb tefflon restbb personal 043.jpg (155.11 KiB) Viewed 2963 times
topcamp
Postby doowop » Mon Aug 16, 2010 10:30 am
Velcro off the shelf for me.
doowop
Postby Frank Addington » Mon Aug 16, 2010 10:38 am
Topcamp
Great looking rest, is that leather? How do you make it?
Frank Addington
Postby topcamp » Mon Aug 16, 2010 11:35 am
it sits on a leather pad that covers the shelf and side plate..........it's made out of tefflon.......carved with a dremmel...............
topcamp
Postby Frank Addington » Mon Aug 16, 2010 11:52 am
Did you see my rest? Do you think you could lift this rest of yours up high like mine? I try and get center shot as close as I can....
My rest is up higher to where a normal rest would sit.
Frank
Frank Addington
Postby Frank Addington » Mon Aug 16, 2010 11:55 am
Here is another view.
Frank Addington
Postby topcamp » Mon Aug 16, 2010 12:28 pm
why would i do that..............??????????..........i want my rest as close to my bow hand as i can get it...............and still get great arrow flight 3 under. maybe you need one that high for the show work...............but i also don't understand why you use wood glue on leather when barge cement is much better and less brittle............you could use teflon that high.......just get a big block of it and whittle out your rest..............glue it down and off you go.............
topcamp
Postby Frank Addington » Mon Aug 16, 2010 1:25 pm
Top
Sorry, what I should have said was that I liked the material of your rest . My question for you was how do you think it would perform up high like I like my rests? I may experiment with teflon... it looks pretty solid. My rest is the most accurate rest I have ever found, for aerial or bowhunting... very accurate. But it is a little too fragile for bowhunting conditions.
I suppose I didn't clarify my question.
Frank Addington
Postby whump » Sat Aug 28, 2010 10:10 am
Whump Sez; I use felt or seal skin . As a hunter I try to un-complicate things. But since all Pirates rarely carried the same sword then as individuals we can learn from the techniques of others. The more complicated anything is the more prone it is to failure, so we can make an assumption that a man with no legs will not have knee trouble. All ways look at the bright side! HUnt safe.
Postby JackDaw » Sat Aug 28, 2010 10:14 am
Whump, you owe me a cup of coffee and some Windex.
JackDaw
