Centershot question...it just doesn't compute
Re: Centershot question...it just doesn't compute
Postby rwsbow » Sun Aug 08, 2010 7:44 pm
Just cut the damn little "plunger" section off and put on a small felt dot....will work wonders!!!!...will bring the arrows back tothe right....
Postby Frank Addington » Sun Aug 08, 2010 11:14 pm
Are the arrows to stiff?
Are you left eye dominant?
Is your anchor tight against your face?
There are some questions ... it is much easier and quicker to fix a problem when you can see the bow, the tune of the bow, and check the arrows, wt of field tips, etc and then watch the shooter shoot.
The questions may suggest some things to consider...
Frank Addington
Postby KCummings » Mon Aug 09, 2010 1:00 am
rwsbow wrote:Just cut the damn little "plunger" section off and put on a small felt dot....will work wonders!!!!...will bring the arrows back tothe right....
I like the way you think Rog.
KPC
KCummings
Postby whump » Sat Aug 28, 2010 9:52 am
Whump Sez: Good information--the learning process continues---and by the way on the wood chuck;: that's why you never see a wood chuck masturbating---his arms are too short. Hunt safe.
