Rebuilding a grip
Rebuilding a grip
Postby Chameleon » Thu Sep 27, 2007 10:37 am
I want to beef up a wooden grip - what would be the best way to do that? Should I get some wood putty or something and build it out and then sand it down? I'm pretty clueless when it comes to wokring with this kind of stuff, but I want to experiment with making a grip that feels just right...
Chameleon
Re: Rebuilding a grip
Postby Feral Donkey » Thu Sep 27, 2007 10:40 am
Where's Hank? Oh, yeah, he's at the boobie bar. I think Hank uses Bondo sometimes. I don't see why wood filler epoxy wouldn't work, especialy if mixed with some sawdust
Postby Hank » Thu Sep 27, 2007 11:02 am
Bondo can work, but I heard that plumber's 2 part epoxy that comes in a tube is real nice to work with. Bondo takes stain real well :)
Postby james wrenn » Thu Sep 27, 2007 2:54 pm
I used the two part epoxy putty like they sell at most hardware stores to build a grip for my 21st Century.It worked great and after it was covered with leather no one is the wiser. :)
james wrenn
Postby mike robin » Fri Sep 28, 2007 5:12 am
either will work ------but the bondo is way easier to tool .you can mix in extra hardener and do some of the tooling in minutes--its also easier to undo
chicks dig me
mike robin
Postby Cutty » Fri Sep 28, 2007 10:54 am
If you don't really want to change the shape, just go a little thicker, you can use a thicker grade of leather for a grip too. I've used quiver leather for grips if I find them a bit too narrow and not only did it work, it takes away a little handshock, without feeling too squishy, or losing some control.
Cutty
Postby Cutty » Fri Sep 28, 2007 10:55 am
Another way to do essentially the same thing is to build a grip out of overlapping strips of leather lace. Gives you kind of a cool wrapped effect too. I got that idea from Doug Witcher from Turkey Creek Lb's. You can pick up the leather lace from Hoby Lobby, or most craft stores pretty cheaply too.
Cutty
