Pirates Of Archery • View topic - Tuning an ILF
Tuning an ILF
Tuning an ILF
Postby Keener » Wed Sep 04, 2019 6:28 pm
So I bought a JC Customs 17" Optimus riser.
Paired it with some tradtech 50# mediums and strung it up. Ive tried off the shelf with the removable stock shelf and then felt pads. Brace is about 8 1/2".
My problem is every arrow Ive tried to bareshaft flies very weak. Like trying to kiss its own ass weak.
Arrows are 500 and 400 spine XX75s. I used points from 125 to 200 grains. Shafts are 30.5 inches.
For what its worth, my arrows work fine on a 55# Super Kodiak.
Any advice?
Some mistakes are too much fun to only make once!
Keener
Re: Tuning an ILF
Postby BEN MAHER » Thu Sep 05, 2019 4:21 am
How far past centre is it cut?
I run near the same on my Titan but draw closer to 29” and with a Flipper rest I’m running 500FMJ’s full length and tippes with 175gns. To most that would be way underspined but the Flipper gets me back to almost centre . Tuning is a pain eh !
BEN MAHER
Re: Tuning an ILF
Postby Keener » Thu Sep 05, 2019 3:00 pm
The riser is cut .270" past center.
I'll need to build that out some or get an adjustable side plate, I guess.
I'll figure it out and make it work.
This bow is FAST, though.
Keener
Re: Tuning an ILF
Postby Keener » Thu Sep 05, 2019 6:49 pm
I might have figured it out. I forgot you can adjust bow weight on an ILF.
My limb bolts were all the way in, I backed them out 3 turns each and tried a bare shaft.
MUCH better flight. Not perfect, but I think I can work with it.
So how much adjustment does an ILF riser have with weight? How far is too far when turning the bolts out (lighter weight)?
Does Viper have a book on ILF stuff? :twisted:
Keener
Re: Tuning an ILF
Postby PAarcher » Fri Sep 06, 2019 5:58 pm
It depends on the riser, but I think you can typically get close to 5# out of most ILF bows. Set something up so that you can adjust the center shot. That will make a big difference.
Re: Tuning an ILF
Postby BEN MAHER » Fri Sep 06, 2019 8:58 pm
BEN MAHER
Re: Tuning an ILF
Postby Jim Casto Jr » Sat Sep 07, 2019 4:20 am
I think the rule of thumb is about 10% adjustment.
Re: Tuning an ILF
Postby Keener » Sun Sep 08, 2019 3:33 pm
I talked with John from JC Customs. He told me a heavier spine arrow was the way to go.
His recommendation is for a .340 or .300 spine shaft. So, I pulled a 100 grain brass weight from an old Blackhawk Carbonwood Vapor 4000 and replaced it with a standard insert. Damn thing flew near perfect.
I pulled the plastic rest out and put on some high tech felt pads, adjusted the nock point and tweaked the brace a touch.
Bingo. Laser beam at 10, 15, and 20 yards bare shaft.
Now I need to get rid of a little twang. Having some trouble getting it "mouse fart quiet".
I put felt on the contact points, made sure all the bolts and set screws were tight, set wool silencers at 1/3 and 1/4 limb positions. I just cant seem to make that last bit of vibration go away.
Keener
Re: Tuning an ILF
Postby Keener » Sun Sep 08, 2019 3:34 pm
And this thing is fast to me.
Keener
Re: Tuning an ILF
Postby Yohon » Sun Sep 08, 2019 6:45 pm
Try it at the upper end of the brace height recommendation.....
