Silly Ass Question
Silly Ass Question
Postby Bender » Tue Apr 23, 2019 1:09 pm
Anybody here make their own strings?
Check this out:
https://www.fenderarchery.com/collectio ... erving-jig
New Pat Pend take on serving jig.
Easy to load/switch serving string spools. Just pull a pin. Easy to adjust tension. Just turn locking nut with included wrench. Easy to thread serving into guide hole. And perhaps most important, once tension is set, no need to screw with it after swapping spools. The adjustment is inboard and remains unchanged when swapping spools.
Do you run different colors/materials for center serving and end loops on your endless loop strings? This just might be for you. :D
