Here are a couple of better photos showing the green coloration of the stripe... Still not as bright as it actually is.
Here is what I am talking about with the shelf. This is a photo of a brand new gray maple riser. Pretty much the same height and shape as on most of my other take downs.
Here is the shelf on the old Green Stripe. It is actually about 3/8" lower and narrower than the rest of my take downs. When you put an arrow on the shelf with out the rest, it is actually laying on your finger. Like I said, the arm on the rubber rest is about the same height above your hand as the shelf is on the other bows.
...and this is another older riser that seems to split the difference between the two....
