which center serving material to buy?
Postby jwillis » Mon Nov 03, 2008 4:04 pm
I'm thinking about getting some 8125 string material for making my Walk the Talk bowstrings. Which center serving material is best for this? Jim
Re: which center serving material to buy?
Postby Hank » Mon Nov 03, 2008 10:49 pm
That #62 braided stuff from BCY is probably good. I think it comes in .026 thickness?
Fishing line is good, just need a good server to put it on with, #25 to #30 test should be about the right thickness. I prefer Cajun Red or Suffix Seige fishing line for center serving.
For me.... nylon and halo slide.
Postby jwillis » Mon Nov 03, 2008 11:15 pm
How about Halo vs. Crown? Or are they both too expensive for what they are worth? Jim
Postby tjdeerslayer37 » Mon Nov 03, 2008 11:48 pm
i made up a 6 strand 8125 string, i just used the nylon serving but had to use 8 extra strands(i think) in about a 1" section of the serving for the arrow. i wouldnt do this for a speed string but i have a fast flight plus string with nylon serving, then it has 20# clear fishing line over that and fits the nocks nicely. but im sure it weighs a lot more than just adding the extra strands for a tiny section of the serving.
Postby jwillis » Tue Nov 04, 2008 9:09 am
TJ, how do you like the 8125? Is it soft like D97 or fine and hard like TS-1 plus? How does it compare to 450+? Jim
Postby tjdeerslayer37 » Tue Nov 04, 2008 9:33 am
jim these are the first couple non-stretch strings ive ever used so i cant really hold a comparison. but to me, the 8125 feels hard thats how id explain it anyway. im pretty sure its smaller diameter than the fast flight plus stuff but i havent put the calipers to ether yet. lol.
Postby jwillis » Mon Mar 09, 2009 4:00 pm
Follow-up on this thread...
I got some 8125 and discovered it makes a nice flemish string with 16 strands and .024 Halo serving. Fit nocks perfectly. The string material is kinda hard and thin like TS-1 plus, but it shoots fine, and is very light and fast. I'm still interested in trying some other string types like the 450+ Hank raves about.
Postby Carbon Caster » Mon Mar 09, 2009 4:07 pm
16 strands is WAY OVERBUILT in my opinion!!!!!! I would not go over 12 strands. 10-12 with .030 Halo works best for me. I have no problem going down to 8 strands as well. I pad the loops to 16 - 18 strands. If you have a way of pre stretching the string after you build it and before you serve it makes a big difference in performance. @200-250# is good.
Carbon Caster
Postby Hornseeker » Wed Mar 11, 2009 8:27 am
We are having standard strings at the event right?? Just curious...
E
Postby Kirkll » Wed Mar 11, 2009 11:27 pm
Hornseeker wrote:We are having standard strings at the event right?? Just curious...
E
had the same question and went back and read the rules myself E... :mrgreen: Strings will be provided for all classes except the open class. in the open class you bulid your own....
Can i use piano wire Ken? or do i gotta stay with 6 strands? :shock:
