metal recurve build
Re: metal recurve.
Postby tjdeerslayer37 » Sun Dec 30, 2007 11:12 pm
i like that combo, looks good.
Re: metal recurve.
Postby Gino Bruno » Sun Dec 30, 2007 11:32 pm
thanks, i really like it too....... when that pic was taken it just had one coat of sealer on it to keep it from moving around...... it looks a lot better after all the pores were filled and the satin finish was applied...... it really highlighted the grain.
Re: metal recurve.
Postby BowDonkey » Mon Dec 31, 2007 3:01 pm
That is some awesome work.
BowDonkey
Re: metal recurve build
Postby Henry McCann » Fri Mar 28, 2008 6:33 pm
New to the site and have been happily lost in reading through old posts. I have learned an incredible amount already. Thanks for sharing all your hard won experience and wisdom!
I just had to write and say this is the first metal riser that I have ever liked and I really like this one. Has to be the beautiful wood inlays.
Henry McCann
Postby Kenro » Fri Mar 28, 2008 7:34 pm
Aw see, there you go teasing me with that metal riserd one again :x you know how I feel about that thing man! :D At the very least put it in a will with my name on it. Awesome buck too BTW! I still have that pic from almost a year ago inside my tool cabinet door at work and still get asked about it from people who see it.
Postby Gino Bruno » Fri Mar 28, 2008 7:45 pm
wow, thanks henry!
ken.... you got it.... if i croak, you get the bow with both sets of limbs lol.
Postby Sixby » Fri Mar 28, 2008 8:59 pm
Gino , I truly admire you sir. That bow is just stupendously awsome. If I were to ever have a metal riser or make one myself it would be with inserts. If you want to share something with me though I woul like to know how you do the stripes in the veneers. I want to do it but have not figured it out yet. If not then I understand that too but those veneer stripes are just awsome. do you do them in a large blank and then cut individual lams off it after its all glued and dried? that is the only way I could come close to thinking how its done.
Sixby
Postby Gino Bruno » Fri Mar 28, 2008 9:08 pm
steve- no secrets here man.... the piece of leopardwood is split down the center and then the two halves are run over the jointer..... then the arcs are cut like i do my risers..... i glued the accents to the zebrawood and then went back and scribed the lines onto each half of the leopardwood. i shaped the leopardwood and then glued the two halves of leopardwood to the zebrawood and accents..... these veneers look awesome with zebrawood and figured walnut.
Postby BLACK WOLF » Fri Mar 28, 2008 11:02 pm
Gino,
I know I've metioned something like this before but I'm not kidding when I say you have to be one of the most talented bowyers I have ever seen!!!
You're work inspires me!
Ray ;)
BLACK WOLF
Postby Bill Grenoble » Sat Mar 29, 2008 6:54 am
Henry McCann wrote:I just had to write and say this is the first metal riser that I have ever liked and I really like this one. Has to be the beautiful wood inlays.
Welcome Henry, Gino is one very talented individual, and there are a lot more like him on this forum, as you will see. Bill
Bill Grenoble
