Pirates Of Archery • View topic - Bow Swap Build for Apex
Postby BK in TEXAS » Sun Jul 12, 2009 9:59 pm
One of the neat things about this swap is that I've had the chance to chat with a couple real nice guys that I probably wouldn't have called otherwise. Good stuff.
So after talking with Marty this is going to be a 1-piece hybrid with a low grip ; 62" AMO ; 52-55lbs @ 27"
Other than that the only request he had was a darker riser & lighter limbs.
Here is my lumber corner: I really really need to do some organizing. Blocks & pieces are everywhere & the pampers boxes are full of unsorted call blanks. Uggg.
Ok...so I narrowed it down to a few pieces. The top is Iroko, middle Wenge, bottom Rosewood.
After staring at them for a good half hour I decided to use all 3. I think it'll work, I just hope it's not to busy. I should know after gluing the riser together.
After a little time with a pencil & eraser I went to the bandsaw & started cutting. I got both accent pieces cut & the wenge piece fitted in the rosewood. That's as far as I got. Tomorrow I'll grind an accent strip for between the wenge & rosewood. Since the Iroko is going to overlap the wenge, I'll need to glue up the wenge/accent strip/rosewood section before cutting out the cradle for the Iroko.
Re: Bow Swap Build for Apex
Postby Apex Predator » Tue Jul 14, 2009 4:50 am
You'll have me checking in a little more often from this point on Bobby! :D
Apex Predator
Postby Hornseeker » Tue Jul 14, 2009 6:12 am
Cant wait to see it come along!
Postby BK in TEXAS » Tue Jul 14, 2009 12:29 pm
Only got a little done last night....had to wait for smooth-on to cure. The Wenge & Maple accent are glued to the Rosewood, and tonight I'll cut out the cradle & fit in the piece of Iroko then glue it up.
Postby michbowhunter » Tue Jul 14, 2009 12:36 pm
Good to know i'm not the only one with a collection of Huggie boxes in my shop. :D
If you say you can, or you say you can't....you're right!
www.journeymanarchery.com
michbowhunter
Postby BK in TEXAS » Tue Jul 14, 2009 11:25 pm
Postby Crooked Stic » Tue Jul 14, 2009 11:56 pm
Canary Marty :) I think I am seeing where you are going with the riser-pretty neat.
Postby Apex Predator » Wed Jul 15, 2009 4:07 am
I definitely like the canary Bobby! You've got me on the edge of my seat man!
Apex Predator
Postby michbowhunter » Wed Jul 15, 2009 5:02 am
That is gonna be a nice looking riser, love that radius layout. :D
michbowhunter
Postby BK in TEXAS » Wed Jul 15, 2009 11:05 pm
Got the riser done tonight. :)
