Connexion Hinge
Connexion Hinge
Postby 4nolz » Mon Jun 15, 2009 5:46 pm
The Connexion Hinge is a two-piece takedown system created by Robertson Stykbow.The Connexion is an option
offered on their bows but it is also sold separately for us novice bowyers to install in our own bows! Installation is simple,
quick and requires minimal tools.
The system is only applicable with straight or slightly deflexed riser shapes.
First,do your blank glue-up
and rough-out as usual keeping the centerline marked.Mark the desired location of the center of the hinge 2"
below the shelf.Use the hinge as a template to mark where the "female" portion will be relieved into the handle.
Use a 3/4" sanding drum to make a 3/8" deep trough for the hinge-be sure the trough is 90degrees to the bow handle.
Now use 2 sided tape (with the centerline marked) Image
place the hinge into positionImage
Be sure you have 1/32" to 1/16" for rotational clearance.
Carefully pre-drill 5/32" holes with the hinge in placeImage
On a glass bow (as pictured) remove the hinge
and drill JUST the glass with a 3/16" bit to avoid plintering the glass. You will be able to hear and "feel" when the bit
clears the glass Image
Next attach the hinge with the supertitanium screws supplied. I like to use MT-13 epoxy
in the holes and on the glass surface at this time Image
Clean excess MT-13 with laquer thinner! Image
NOW CUT YOUR BOW IN HALF! Use any means at your disposal as long as the cut is perpendicular-obviously
use caution to avoid the metal hinge! I use a chop sawImage
Re: Connexion Hinge
Postby 4nolz » Mon Jun 15, 2009 6:00 pm
Next install butt plates.I use 2 pieces of .050 glass
which corresponds to the thickness of the material lost to the saw blade.Use plastic wrap to protect the hinge and
trough from the epoxy.Epoxy the plates in postion with the bow strung to apply pressure during curing.Image
At this point I like to apply "faux" grip overlays to the hinge ends Image
Finish shape the bow Image
A rubber roll on shur-grip covers the hinge cosmetically or you can make a "faux" leather lace-up grip with velcro Image
VIOLA! Note the grip overlays-a nice touch Image
The Connexion Hinge can be ordered from Roberson Stykbow
989 Stykbow Lane Forest Grove,Michigan 59441. Call 1-406-538-2818 or email stykbow@midrivers.com.
Re: Connexion Hinge
Postby 4nolz » Mon Jun 15, 2009 6:14 pm
nowadays I use a phenolic piece with the center cut out and glue on "over" the hinge before cutting the bow in 1/2 .(sorry no pic)
It helps with the "feel" of the grip and makes the hinge less palpable-I used to use moldable epoxy (like on TJ's bow).Image
I also use heel overlays now it helps with the overall appearance.
Re: Connexion Hinge
Postby tjdeerslayer37 » Mon Jun 15, 2009 7:43 pm
hey thats my bow! and a heck of a bow it is. 8-)
thanks for the build along nolz
Re: Connexion Hinge
Postby TimZeigler » Mon Jun 15, 2009 8:46 pm
Great post Mike! Looks like something I'd like to try.
Tim
TimZeigler
Re: Connexion Hinge
Postby BK in TEXAS » Mon Jun 15, 2009 10:03 pm
That's pretty cool Mike.
BK
Re: Connexion Hinge
Postby Carbon Caster » Mon Jun 15, 2009 10:55 pm
Thanks for taking the time to post that here Mike. I am sure I will still mess mine up somehow, but I have to try. :lol:
Carbon Caster
Re: Connexion Hinge
Postby Jon in Montana » Wed Jun 17, 2009 9:19 am
Think I might have to try that!
Just a quick note - Robertson Stykbow is in MONTANA, not Michigan. Common mistake - MT looks like MI sometimes.
Jon in Montana
Re: Connexion Hinge
Postby MOUNTER » Wed Jun 17, 2009 1:21 pm
Great tips, might try that on a BBO. Question, is it a hindge or can you pull them apart in two pieces?
Re: Connexion Hinge
Postby tjdeerslayer37 » Wed Jun 17, 2009 1:26 pm
When the hinge is opened to 90 degrees it comes apart into two pieces
