Straight limbed glass longbow Build-Along
Postby tjdeerslayer37 » Sat Nov 24, 2007 8:39 pm
Hi all,
Im building a 62" straight limbed longbow for my mom. She doesn't hunt, just shoots. She gets cold and bored too easy, lol. :roll: She's currently using my old compound to shoot but I figured id make her this bow and maybe she'd be more into it. :idea: I let her pick all the woods, and i "designed" the accents and what-not. So lets cut to the chase. :D
First off, I want to be sure that everyone knows this is only my second bow and if I do anything wrong please let me know. I pretty much just do what i learned from the Binghams insructions and from reading online. Also whenever im building anything its at my grandpas house, cause he has all the tools and the knowledge. :D So along the way hes always pointing out things i could do better and what not.
Kay, I ordered all the materials from binghams and as usual they were great to work with and helped me with the task of shortening the bow and also the riser.
First thing i had to do was make the form. Since it's just a straight limbed bow the form was super simple. Glue and screw a few pieces of Particle board together until it come out 1 1/2", cut it through the middle, run the bottom half through the jointer, cut out the riser area, drill for the brackets and lay down the formica strip. You'll see it later on.
The next thing i had to do was lay up the laminations in the riser block. I made sure none of the accents went too far into the fadeout area. This is how the handle was glued up from top to bottom.
Birdseye maple, 1/16th" purpleheart, 1/16th" red phenolic, 3/8" purpleheart, 1/16th" red phenolic, 1/16th" purpleheart, birdseye maple.
whew guess id better show you.
Heres the pieces before i split the maple in half,
Before glue.
Heres the block before clamps, lol, i had to make sure nothing would slip up. ;)
And fresh out of the oven.
The Next step was to cut the block to length and rough cut the fade outs. I used the template from the blueprints for the fade outs but i used a 16" riser instead of the 18" that they use for the 68" bow.
Here it is right after rough cutting. I got pretty darn good glue lines in the riser if i may say so myself. :lol:
Up close.
Next, I sanded down the fades to the line and super thin at the ends, but im afraid i might not have gotten them as thin as i could've i was just afraid of tearing through them. There should'nt be anything wrong with it though as i didnt leave them that thick just not see through for a whole 1/2" they're see through for about 1/4"
Sanding.
Pretty thin.
Glue up was next. :o I guess i don't find this as stressful as some people do. lol. The limbs are laid up like this.
Clear glass, purpleheart parallel lam, two parallel actionboo lams, one tapered purpleheart lam, clear glass.
I laid it all out, brushed all the dust and stuff off, then started putting on the glue. I use Smooth-On. Also i realize i should've spliced the two parallel lams together but i didn't. oops. :shock:
All laid out in order.
Glueing.
Its hard to take pics while laying up the laminations so i dont have pics of that but i have them of the bow in the form. I placed all the laminations in the form, lined them up, bolted on the top, and inflated the hose to 65 PSI. Off to the oven for 4 1/2 hours.
Ready for the oven. I know i shouldn't use the plastic wrap stuff but i made sure none of it was in the laminations before i threw it in the oven.
After the bow was out of the oven i needed to lay out the limbs with the templates. When tracing the limb templates from the Binghams blueprints i found that there wasnt a true centerline on it, plus i didnt like how the limbs narrowed so much towards the handle and i felt that the handle should stay wide. So a nice guy from the LW drew me some templates on a CAD program and emailed them to me.
Tracing the limb profile. I know the template is off center here, but it doesnt matter because i was just making sure there was wood on either side of the template and the riser slid a little bit during lamination.
Then rough cut and sand the limbs to shape. Heres where i really wish i had a belt sander. :x
After that i filed string grooves and i had to find out which limb was stronger and made that the bottom limb and i also checked for limb twist and adjusted where needed.
Braced. (This pic was after the overlays were on and the tips were filed. :roll: )
Next i put on the tip overlays and handle accents. Since i don't get to go to my grandpas house much i glued all the overlays on at the same time. BAD IDEA. It's a pain in the butt to get everything lined up and on the handle theres simply no place for clamps.
Tips, birdseye maple on 1/4" red phenolic.
On the handle we took a piece of 2x4 and cut it to fit on the fadeouts then clamped the whole thing. :idea:
The whole thing.
Then i had to draw out how i wanted the riser shaped and where the shelf was to be cut. After it was all drawn out i rough cut it with the bandsaw and started sanding with the drum sander.
Also i drew out the tips and rough shaped/cut them. And yes i realize they're HUGE :shock: but thats how mom wanted them and they dont seem to affect shooting much.
Drawn out.
Shaping.
Hand sanding.
Filing the shelf. Notice the tape on the file and the aluminum on the window so i dont accidentally cut something i didnt want to.
Then i started rounding off the handle and the accents and continued on the tips.
The sanding block works a little but i liked just using the sandpaper better.
Rounding the back. Sharpies and sandpaper worked pretty good. lol
Filing the tips.
Tips.
I dont have any pics of me tapering the ends of the accents but i just put the aluminum flashing stuff up the butt of the accents then sand down as close as i can then sand to the glass without the aluminum on there.
After a BUNCH of hand sanding and a little power sanding i had everything shaped how i wanted it to be. All that was left was to sand all the clear stuff off the glass and then sand the whole thing from 150 down to 320 grit sandpaper and then i finished it off with 0000 steel wool before finish. Ive got two coats of gloss on it right now so it needs a couple more coats and the last one or two are gonna be satin.
Heres the bow with the two gloss coats.
I was shooting for 45# @ 28" but i really dont know where it's at as i dont have a scale to weigh it on. Once ive got it completely finished ill try to find a 2x4 and use the bathroom scale trick.
Ill post final pics once its finished completely. It might be a couple days.
Any comments, questions, and critisism (sp?) are welcome.
Re: Straight limbed glass longbow Build-Along
Postby rwsbow » Sat Nov 24, 2007 9:29 pm
TJ, that was truly awesome..you got a TON of talent, young man!!!
Great looking bow!!!
Got ajn idea your Mom's gonna love that bow!!
Jolly Roger
(This kid makes me sick..no one should be that talented at such a young age!!!)
Postby Bullofthewoods » Sat Nov 24, 2007 10:10 pm
TJ, awesome job my friend. That is one fine looking bow. I thought you said this was only your 2nd? I must have read it wrong. Nice work :!:
"If you're not actually hunting, you're either dreaming about past hunts, or planning ahead for hunts to come. When does this ever end?" It doesn't. And I can't explain it. That's just the way hunting is.
Bullofthewoods
Postby Gino Bruno » Sat Nov 24, 2007 11:05 pm
fantastic job TJ!!!!!!!!!!!! so are you planning on doing this as a profession?...... i think you could go a long way with this stuff..... by the way, i always use the plastic wrap on glue up just as you did, there is nothing wrong with that and most pro bowyers use it as well...... keeps the glue off the form.
i told you guys this young man was good :D
Postby Cutty » Sun Nov 25, 2007 1:18 am
Thanks for taking the time to contribute that! I love the way the purple heart lams look in the limbs. Really like your shelf as well. Now I'm embarrassed I haven't taken the plunge yet myself. :oops:
You've inspired me big time.
Cutty
Postby KCummings » Sun Nov 25, 2007 6:19 am
Nice Job TJ...
I wish I had 1/4 of the talent some of you guys have.
KPC
KCummings
Postby tjdeerslayer37 » Sun Nov 25, 2007 8:02 am
Gino, Thanks. i have thought about it but theres one thing i dont think i would like. i would rather not have a waiting list of bows i HAVE to make id rather make them then sell them. i think if i had the whole waiting list thing then it would make it more like work and i would like it as much. :D
thanks to everyone.
Cutty you need to build one now. just keep telling yourself "if that 15 year old little kid can do it so can i" :mrgreen: oh yeah about the shelf, my grandpa had fits when i drew that out he just kept saying that it should be the same radius on both sides of the high point. lol. i just continued. :twisted:
Postby Hank » Sun Nov 25, 2007 11:47 am
I wrap my form with plastic wrap, the girlfriend, the cats, dog and anything else I need to :)
Did you decide before the glue up which limb was going to be the bottom, or waited until after you had a string on it to see which limb was stiffer?
Postby tjdeerslayer37 » Sun Nov 25, 2007 5:23 pm
waited till after i strung it cause i bought the lams rather than grinding my own so i couldnt make one stack slightly thicker than the other or anything.
thanks again
Postby tjdeerslayer37 » Sun Nov 25, 2007 5:52 pm
Hey guys,
This is TJ's mom and I just wanted you all to know that this kid amazes me each and every day!!! I am a very lucky woman to have such a talented child...My bow is absolutly beautiful, he did an amazing job!!! THANKS T.
xo mom
