Pirates Of Archery • View topic - Anatomy of the LIF Hunting Riser
Postby Bobmeister » Fri Feb 24, 2012 10:29 am
I have been asked to build two 14" risers and if I could do a build along at the same time. It sounded fun so here we go.... :)
These will be made from Cocobolo, Bocote, Black Phenolic and Maple
The risers will be 14" overall in length with 18-1/4 degree limb beds. This will give them an approximate 1.8# gain over limbs rated on a 17" riser.
Here are all the materials gathered up
Here the pieces cut on the table saw to make the riser block sammich (wood is the bread and canvas phenolic is the meat)
All glue surfaces are scratched up with a hacksaw blade To help with the mechanical bond
I hate it when you go to clamp your parts together and they start sliding all over the place because of the Bow-Snot,so I put a 1/4" dowel in the corners that will be trimmed off.
Epoxy applied and all clamped together. I then put them in the hot box with two 60 watt light bulbs this will keep them at about 80 degrees to set up over night.
Bobmeister
Re: Anatomy of the LIF Hunting Riser
Postby Trux » Fri Feb 24, 2012 11:27 am
Thanks for the build along- looking forward to seeing your progression and the finished riser.
Trux
Postby Bradford » Fri Feb 24, 2012 12:50 pm
Looking for information on LIF bows is what led me to this site!
I like the dowel idea.. I to hate the wood sliding around and it always seems to do so...
14" seems like a really small handle.. what is the advantage to such a small riser.. or is it just a personal prefrence?
God gave you hands, use them!
Bradford
Postby Bobmeister » Sat Feb 25, 2012 6:50 pm
Bobmeister
Postby Bobmeister » Sat Feb 25, 2012 7:03 pm
Now I want to set up the radius jig on the bandsaw and double check for squareImage
Came out good glad that part is done
cleaning the kurf marks off the cut, then I will dry fit the pieces together
Bobmeister
Postby MOUNTER » Sat Feb 25, 2012 7:22 pm
Lookin good Bob!!! I'm always impressed by your top quality work!!!
Postby Bobmeister » Sat Feb 25, 2012 7:44 pm
I took my time and got a good fit and then double checked the dry fit.
Going to use the wooden dowel thing again to keep things from sliding around
Always DO THIS before-
you do this
All clamped tight ready to put in the box at 80 degrees over night.
Bobmeister
Postby Jess Stuart » Sat Feb 25, 2012 8:31 pm
Nice job as always Bobmiester, thanks for taking us along.
Jess Stuart
Postby Jumper » Sun Feb 26, 2012 10:44 am
Man Bob, your work looks so precise compared to mine :oops:
I love the grain pattern in those pieces of Bacote and Cocobolo. These risers are going to be beautiful. The Black Max limbs mediums are on order and a buddy has tied up the Flemish twist strings also! Like waiting on Christmas :D
With God, all things are possible.
Jumper
Postby Bobmeister » Mon Feb 27, 2012 10:00 am
Inspecting the blocks after glue up. So far so good....
Now I will grind them to clean off the excess glue and to the desired thickness (1.75")
Next I will layout the profile with my template
Trimming the fat off the ends with a miter saw
Bobmeister
