Take down recurve build along
Postby Bradford » Wed Feb 15, 2012 10:51 pm
Hey all.. new to this forum but I have been building bows for about 4 years now. I am currently working on one for a guy at work. I see there has not been a build along on here for a while, so I thought I would post mine!
I am doing a take down recurve.. 62" with a 18" riser. He wants it to pull in the mid 60 lbs area. So off we go..
picked out some awesome Honduras Rosewood and fiddle back maple. I know this guy will show the bow off to everyone so wanted to choose some really choice wood.
I glued up 3 pieces of the fiddle back so this handle will be stout. Squared it up and then I glue the rosewood onto the bottom of the maple with tightbond to hold it together when I cut the shape.
I also cut up a couple of pieces 1 3/4" wide and 1/4" thick.. glue together so I can cut out a lam veneer
After cutting up the lam accent, I throw in a few stripe pieces and glue it up. Cut it down the middle and throw it on the drum sander
God gave you hands, use them!
Bradford
Re: Take down recurve build along
Postby Bradford » Wed Feb 15, 2012 10:55 pm
Then I cut the first section of the riser and glue it up
Cut my limb pad angles (19 degrees)
Cut up the second accent area
Then glue it up
Also made a new limb form for this bow. Has a bit more curve at the tip than my other bow form
Bradford
Postby Bradford » Wed Feb 15, 2012 10:57 pm
Glued on some phelonic to the pad areas for extra support
Made some of the first shaping cuts
I start the handle area by sanding out the "trench" with the dremel. I use a depth gauge so I know how far to go
Cut the window and start to radii the shelf area
Bradford
Postby Bradford » Wed Feb 15, 2012 10:59 pm
Then tonight I got some good sanding and shaping done
Tomorrow night will be prepping for the limb build. I have Friday off and want to get both limbs glued up!
Bradford
Postby ojibwe » Thu Feb 16, 2012 4:14 pm
Looking good...like the contrast of woods!
VJ
ojibwe
Postby Bradford » Fri Feb 17, 2012 10:52 pm
Thank you kindly!
Got my lams prepped and the new form built
Then got the first limb built and out of the oven..
Got work tomorrow.. but Sunday should get the other limb built and get both bolted on the riser for the center line
Bradford
Postby Bradford » Sun Feb 19, 2012 7:39 pm
Got the other limb built today.. cleaned it up and set them both against the riser
Installed the insert and pins
Then bolted it all together, taped it and drew out my lines
Bradford
Postby WillScarlet » Sun Feb 19, 2012 9:58 pm
Great presentation,.........I love build-alongs. Bow's looking sharp!
Will 8-)
WillScarlet
Postby MOUNTER » Wed Feb 22, 2012 10:32 am
Welcome aboard!!! Thats gonna be purty.
Postby bearauto11 » Wed Feb 22, 2012 10:41 pm
This is fun to watch. Thanks.
