3 pc build along
Re: 3 pc build along
Postby hera » Thu Feb 28, 2008 9:26 am
Wheelie_Pete wrote:Hera, you glue the overlay laminations together, then you shape them, then you glue them to the limb tip, correct?
Yes I do.
hera
Postby hera » Thu Feb 28, 2008 9:30 am
Do you shape the bottom of the overlay to match the limb curve before you glue it on?
No ,I don't.
hera
Postby hera » Thu Feb 28, 2008 9:31 am
Wheelie_Pete wrote:Hera, do you clamp it into place and bend it with clamping pressure?
Yes,I do.
(LOL :D ;) )
hera
Postby hera » Thu Feb 28, 2008 10:25 am
Cut the bamaoo veneer by bandage scissors.
Thank you Jim,you gave me these fantastic lacewood veneer as a gift.TKS again.
hera
Postby hera » Thu Feb 28, 2008 10:28 am
Yes,I using my hand as a clamp.
hera
Postby hera » Thu Feb 28, 2008 10:38 am
Since I using wenge and bamboo as the riser inlay,I should use them as the riser overlay.
My wenge plate are thick(0.3cm),so I have to sanding it to 0.1cm in thickness.
Sorry Jim,I grinding the lacewood away.
Wenge wood are stiff,I have to use a real C clamp.
hera
Postby hera » Thu Feb 28, 2008 10:40 am
hera
Postby hera » Thu Feb 28, 2008 10:42 am
hera
Postby jwillis » Thu Feb 28, 2008 2:58 pm
The wenge looks better with the riser stripe. You'll like the way those lacewoods look under glass on limbs. Jim
Postby Kirkll » Fri Feb 29, 2008 8:07 am
Very nice hand workmanship....very nice....Kirk
