Pirates Of Archery • View topic - Bowswap ILF Build-along - All Done!
Re: Bowswap ILF Buildalong - 4 4Nolz
Postby BK in TEXAS » Wed Aug 11, 2010 2:02 pm
Postby Ben » Thu Aug 12, 2010 6:23 am
Well, i'm no take down expert,, i've built all of "2" :o
But the 2 i built was for a 21degree pad, so's i be thinking my form ain't gonna work.
What Ya'll think
Everything is simple, people make it complicated
Ben
Postby jwillis » Thu Aug 12, 2010 9:56 am
Postby BK in TEXAS » Thu Aug 12, 2010 10:54 am
Postby BK in TEXAS » Thu Aug 12, 2010 11:06 am
Ok...so I got the first set of limbbs on a riser finally.....looking like 50@28 before rounding stuff off and sanding....perfect for me...little light for Mike....guess the first set is mine ;)
Soooo.....I double checked the stack of the second set of limbs and decided to take off .003. I figured that would be about 2-3lbs. Glue-up same as the first set...blah blah blah, no pictures, look back a few pages for the first set...same thing thicker stack.
Second set out of the oven. I decided to try a little different way of aligning the limbs on this set.....using tiller blocks. Seemed to work just fine. I simply kept adjusting the block until the limbs laid flat. I drew the limbs back a few inches now and again to see what the tips were doing along the way. I'd say it took about a half hour, but I did like this method.
Once the blocks were set where I wanted them, I marked where the string laid on the belly and marked around the block itself (see pictures)
Postby BK in TEXAS » Thu Aug 12, 2010 11:21 am
Next I marked the centerline on the back and laid my template on the limb, traced it, and roughed it out same as the first set. Flip back a few pages if ya wanna see pics.
Apex has a great tip-along in the "Frequently Asked Questions & Damn Good Information" subforum here: viewtopic.php?f=53&t=10446
So, while I won't go into too much detail about mine, here is how I do it....
I start by making a dot on the limb face where I want the nocks to be. I grab a chainsaw file and eyeball the cut in one side so the top of the cut is inline with the dot. My cut is more or less 45˚ to the limb. There is no need for me to make a 90˚ cut since the string angle will not even come close to that even at full draw. Heck at 28" it's still less than 45˚
For the second cut I put a straight piece of whatever is handy in the string groove and clamp it to the table. I used an allen wrench in this case. Then I just take my chainsaw file and start cutting, making sure it's inline with the straight round thing ;) Do this enough and it'll come out pretty darn close to perfect.
Postby MOUNTER » Thu Aug 12, 2010 11:23 am
Lookin good! I've been wanting to try some tiller blocks. Did you buy or make your own??
Postby BK in TEXAS » Thu Aug 12, 2010 11:28 am
Slip on a string and go see what we have!
I bottomed out the ILF bolts then backed them out 1 1/2 turns.
Braced
Full draw...... At 28" we have......60lbs :D sweet. After finishing her up she should sit right around 57lbs. I think you can back her out another couple turns too if you want it a bit lighter.
Postby BK in TEXAS » Thu Aug 12, 2010 11:30 am
Postby 4nolz » Thu Aug 12, 2010 2:10 pm
MOUNTER-I will send you a set-on the way tommorrow.
I LOVE the idea of putting something in the first groove-simple as that man I have been doing it the hard way!!!!
