Pirates Of Archery • View topic - Bowswap ILF Build-along - All Done!
Postby BK in TEXAS » Tue Jul 27, 2010 4:24 pm
Let me first say this is going to be a LONG build-along as I'm posting it real-time as I make the bow. Expect it to take 4-5 weeks. :shock:
Ok...so after chatting with Mike a bit I'm going to be making an ILF recurve. He said he'd rather it be tough than pretty & around 55lbs. That leaves a lot of room to work with :D
So...starting with the riser. The darker wood is Chechem, the lighter yellowish is Canarywood. Both blocks have a 1/8" Phenolic I-beam laminated in them.
Ibeam
Riser layout
Re: Bowswap ILF Buildalong - 4 4Nolz
Postby BullMtnArchery » Tue Jul 27, 2010 4:49 pm
This will be a good build-a-long. Which riser block is for 4Nolz? I like the Checem has some nice figure in it.
Look forward to more. Brock
"Never mistake kindness for weakness"
"Character is the type of person you are when no one is around"
BullMtnArchery
Postby BK in TEXAS » Tue Jul 27, 2010 4:59 pm
Postby Crooked Stic » Tue Jul 27, 2010 7:39 pm
Keep it comin.
Postby Feral Donkey » Tue Jul 27, 2010 7:45 pm
That's going to be stronger than hell!
Postby MOUNTER » Tue Jul 27, 2010 7:54 pm
Lookin good BK! I'm gonna use some canary in Brock's bow, I like the looks and it's seems pretty dense......
Postby BK in TEXAS » Wed Jul 28, 2010 6:54 am
Postby BK in TEXAS » Wed Jul 28, 2010 7:04 am
Starting with 2 planks of Moso old-growth carbonized bamboo flooring.
First I cut them to 1.5" wide, then I put a zero clearance insert in the table saw,
flip them on their side and slice them into 3 lams.
I get 6 rough lams from each plank.
Grinding on the 6x48 sander flipped verticle.
2 bows worth of cores!
Postby 4nolz » Wed Jul 28, 2010 7:27 am
wow that makes me feel like a hack!
Postby Jon in Montana » Wed Jul 28, 2010 9:13 am
Looking great!
That bamboo flooring looks like something I'd be interested in! Hope you don't mind a few questions...
Any issues with the glue coming apart during glue-up (not the smooth-on, but the original factory glue)?
Do you flip the lams (side to side) during glue up so the factory glue seams offset each other?
Is there a good online source?
Jon in Montana
